Large ceramic shell burnout kiln for lost wax - Zapins
Discussion in 'Furnaces and their construction' started by Zapins, Jan 3, 2019.
  1. Zapins
    Solid ideas. I'll see how the flame burns before mig tipping it. My main furnace burner is just a hole it a cap and it works well.
    I can use the battery charger for sure.
    I would burn out today but.... torrential rain. Of course. I'll probably just get it all spruced up today and do some of the stuff I was going to do later on after burning out now. Painting, door springs, grinding, etc. It is 55 f outside now.
  2. Zapins
    Due to recent furnace upgrades to my blower assembly the car battery charger I previously used is now free for the soldenoid.
    The furnace is very nearly done. Just a few more mostly cosmetic things and it will be totally done. I'll probably paint it tomorrow just before use.
    I put a coat of satanite on it. One water thin coat used up 2.5 lbs. Very surprised at that. How thick exactly does the stuff need to be applied?? Is one coat enough or should I add a second coat? I bake each coat individually right?
    I also added another row of spikes to the rack to support shells.
    I'll weld on the wall supports when I'm done boating with satanite. Much easier to paint walls without bars in the way.
  3. Zapins
    Damn that took me forever. Its finally finished. I edited a short video of the kiln during its maiden voyage.
  4. DavidF
    OH YEA!! :D
  5. Petee716
    Nicely done!
  6. Zapins
    3rd use now. It burns molds out well but the panels are developing large cracks. It is concerning for long term usability. I am worried the panels will crack all the way through and fall out, especially the main side door.
  7. Al2O3
    It's possible the coat of Satanite did that. When it was fired, the Satanite surface shrank. The bond and shrinking force overcame the insulating fiber board.
    Here's a piece of IFB I coated with thinned mortar and it did this without being fired. If it's fully cured the Satanite may not shrink any further. If not.....you may experience a little more movement of the fiber board.....but hopefully not.
    Do you know, is the fiberboard rated for use in fuel fired furnaces? Seems like natural gas should be pretty clean so lower chance of chemical attack......Melterskelter recently mention this in regard to ceramic wool in his Satanite thread.
  8. Zapins
    Hmm that's interesting and unfortunate. The board was 2600F rated.
    That looks exactly like what happened to me including the same curve direction bowing towards the flame.
    Hopefully it doesn't move much more. But as it is the door won't close now because of the bowed panel. I might have to cut the board down the center to relieve the stress and then seal it with more satanite once it is on the wall again.
    The good news is after 3 hours of run time I don't see any bowing of the 3/4" or 1/2" stainless steel grating or a huge amount of scaling for that matter. So that seems to have worked out so far.
  9. Melterskelter
    Interesting observation about the shrinkage of Satanite. This must be a very frustrating occurrence. Not an appropriate reward for your diligent efforts!
    It might be interesting/useful to accept that shrinkage and allow for it by incising the wide flat surface of the panel at intervals perhaps in a checkerboard pattern by cutting 1/4th of its thickness with an old skill saw blade or masonry blade. That would allow the shrinking surface to behave more like a bellows and not a like flat asymmetricly shrinking sheet. To do this cutting would require removing the panels from the frame. I assume doing so would not be too onerous.
    How would a person figure what interval to use? It looks like a single crack occurred near the middle the wide panel. So, intuition would suggest to me that reducing the expanse from the crack to the edge to 1/3 the distance might be enough to allow the inevitable shrinkage but not overstress the board so that it cracked. So, if that panel is say 30 inches, I'd try a grid of cuts every 5 inches. Perhaps the cracking as it is occurring will, as Kelly suggested, provide adequate stress relief by itself.
    These refractory materials are trying to teach us all lessons!
    Added a few moments after posting: I would expect to coat the cuts with Satanite.
  10. Zapins
    Yep I think I'll try one cut down the center along the fracture line to start with. Hopefully that fixes it. I want to stay away from multiple cuts because I've noticed that fiber blanket/panels seem to get more brittle the more flame time they see. And they would be more likely to crumble if in smaller bits.
    I'm shocked at how much wax I got back. I must have salvaged 20 lbs of wax from the burnouts I did today. That's a buck a pound I can reuse. Cha-ching!
    Here are some pics of the cracks. And a few pics of the burned out shells and the furnace again.
    20190126_232948.jpg 20190126_232918.jpg 20190126_233015.jpg 20190126_233031.jpg 20190126_233336.jpg 20190126_205215.jpg
  11. Jason
    Sorry to see that... Now take your savings and cast some panels out of proper refractory cement about 1/2" and throw your panels in the trash. You tried, but they are shit man.
    You would have been better off with monkey crap spread on some kaowool for the walls.
    Kell, I'm pretty sure zap has this rig running on proPAINintheass.
  12. Zapins
    Haha. I think I'll wait for them to totally crumble and fall out first. The panels weren't cheap. Might has well get some kind of use from them!
    On the bright side of things I got the solenoid setup ready. I will connect it up to the PID soon and make a box for it.
    And what's wrong with propane other than the expense?
  13. Jason
    Hauling the stuff. I'm forever out when I need it the most. When I moved to Texas, I tossed my propane grill in the trash. It's charcoal and mesquite for me only. The best steak I can find comes off my $30 walmart grill! Not easy getting it to go Chernobyl, but when it does, it seers the meat to a crisp and leaves the inside nice and juicy.
  14. Al2O3
    How are the panels secured to the kiln structure? In addition to the shrinkage of the dissimilar materials, if the panels are anchored instead of floating in the metal structure (i.e don't "caulk the corners"), that can be a further aggravation to panel breakage. Your burn out kiln is no different from our furnaces when it comes to the stress of thermal cycling and thermal shock.
    Ok, I thought I had seen earlier in the thread Zap looking at his residential natural gas supply. Probably doesn't matter because the burn of either can be well tuned. The reason I was asking had to do with the furnace atmosphere and whether or not the presumably reducing atmosphere would potentially attack the bare fiber board. The temperature rating of the fiber board is potentially only part of the story regarding its survival. Melterskelter noted that wool in his furnace environment was attacked, not just by heat. I've been doing a lot of poking around, and while true that most of blanket, paper, and fiber board insulating materials are based upon the same material, some are not and some have different binders. For instance, I have some moldable version of the same and when cured, it's actually rated for continuous metal contact with aluminum whereas bare wool is rapidly dissolved by metal contact.
    At this point, just coming trying up with ideas to help out, I do think Melterskelter's suggestion of cuts does offer some relief to the residual surface stress but the damage may already be done to the larger panels and this may have to be done prior to first firing. Instead of one panel that bows a lot, you have several that bow less, and maybe not enough to fracture the smaller panels. That shrinkage is the same for every lineal inch in all directions so cutting the panel in half in one direction while leaving the other one necessarily get you home.
    All of this is why commercial kilns are usually mechanically contained IFB instead of mortared brick......all the joints allow movement without breakage and deformation.
    One last thought, the hole in the pipe cap is elegantly simple for the burner, but a tunable naturally aspirated burner might provide a little better tune, control of furnace atmosphere, and economy in propane usage. As far as the fiber board compatibility, maybe replace the panel on the door and don't coat it to see how it holds up. If you don't coated it or anchor it to the frame, it may stand up fine, but will be more susceptible to mechanical damage from your furnace contents.
  15. Jason
    The closest thing we've seen around here is that 4 piece furnace made out of castable sections. How is that thing holding up? When I saw that one, I had the same nagging thought about thermal expansion. hmmm. Now Glen in Taiwan uses some kind of inch thick board for his little forge. (gstongs on yt) He has no mechanical fasteners, just gravity doing the dirty work. Again, a loose fit is critical. Heat does some strange things that's for sure.
  16. DavidF
    I see you burnt out the lost pla auger?? how did the shell hold up and when can we expect to see a pour??
  17. Zapins
    The panels are secured by being stacked in place. There are some metal L shaped tabs to prevent the boards falling out and there is some caulking on the inside of the furnace to seal the gaps between boards but it doesn't really glue them together in any way. The steel panels are welded along all edges to the L shaped frame on the outside of the panels.
    I'd love natural gas, but the other thread was at my friend's house not mine up in CT. Unfortunately I don't have a gas line, although I have seen a natural gas line in the woods while hiking not too far from my house so it seems to be in the area.
    The lost PLA shell actually seems to have burned out very well. I'm really surprised. I don't hear any rattling around inside the shell at all so I assume the 1/2" to 3/4" core somehow held up to burnout. The PLA actually melted out like wax, it dripped out of the mold. It contaminated the catch pan full of wax in lumps and lots of drips of hard black plastic. I don't know if I can separate out the PLA from the salvaged wax but I am hopeful since its mixed in with about 10 lbs of wax.
    I'm hoping to get most of these things cast today so with any luck I'll post photos later tonight with results.
  18. DavidF
    Looking forward to seeing that!
  19. Zapins
    Looking like in 2 to 3 hrs from now I'll be doing the first pour. Starting up the furnace now but I need to slowly burn out the refectory that I recently added before taking it up to full power. That should take about an hour then I'll crank it up for the second hour and pour.
    Maybe I'll do another YouTube live casting?
  20. DavidF
    Pour that auger first, I want to see how it comes out..
    Live video would be cool :cool:
