I made a 2 part mold using Mold Max 60, thinned by 5% to make my wax parts. The two molds created great parts. I didn't condition the molds (heat at 125 degrees for 4 hours) since I would be making wax parts. I've only made 6 or 7 wax parts (Freeman Ruby Red) and I found the mold is deteriorating at a very rapid rate. The internal threads are breaking up and I'm getting tears in a thin section. I sprayed the mold with mann mold release 200 prior to pouring the wax. I don't know the temp of the wax. I heated it as low as possible on my kitchen stove and poured the wax as soon as it was liquid. Is there a better mold making material I should use? Should I cut a slit in the mold to allow easier removal from the main part? I'd appreciate any suggestions. Thanks
This.. https://www.alumilite.com/products/plat-55-silicone-rubber/ Do not thin!!! And does well even if you don't vacuum degas.
I'll give that a try. I am degassing prior to pouring it into the mold. I started using thinner because it's 90 degrees in my garage and I had problems when I poured it into the mold. I was getting small air bubbles. My vacuum chamber isn't big enough to degas the mold with the silicone in it. Thanks again for the tip on the product to use.
It just so happens I bought some turquoise too. I'll give that a try. Now, to get the ruby red out of my camp cup. Thanks again
https://www.reynoldsam.com/product/econ-60/?pk_campaign=ramdyn&pk_kwd= got molds made of this that are 10 years old ..still producing nice waxes...best stuff i've found....
Thanks CrazyJoe86. I'll give that a try. I hope they have some in stock. Seems some of the ingredients are hard to get.
