What Projects are People Working On/Wanting to Work On?
Discussion in 'General foundry chat' started by Tops, Jan 15, 2024.
Tags:
  1. Al2O3
    Make sure the wing nuts are steel and not zinc.
  2. Tops
    Oh man, I never thought about that as a failure mode (zinc hardware melting in foundry service), thanks. They check out as steel with a magnet.
  3. Tobho Mott
    Definitely worth checking... Before and after :D
  4. Tobho Mott
    So here's appx. 454# of new greensand. Should be more like 470 if you include the water. I know for sure I used up #400 worth of silica by counting the empty 50# sand boxes. I did decide to hold back 100# of my original 500# of 56GFN silica. Maybe I'll need to make some cores or more facing sand some day... So, I'm finally done mixing this stuff up!
    Tops, Mark's castings and Dan Dubeau like this.
  5. Tops
    A little more progress on the pouring shank.
    I have a question: about what angle would seem best for the assist handle?
  6. HT1
    about 15 . i tack mine in place then play with it til im happy, always ends up about 15
  7. Tops
    Thanks Henry. So about like this? Assuming rest square/level to world and small handle angled 15 degrees toward ground. tops_a10_shankring4.png
  8. HT1
    Not entirely sure what angle you want so here is one of my 3 shanks
  9. Tops
    Thanks! Those pictures are perfect.
    HT1 likes this.
  10. Rob Hall
    Rob Hall Silver Banner Member
    Working on getting A furnace, ANY furnace going. I have been waffling badly since my move to Michigan, I finally got the urge to get some aluminum melted.
    Got a metal food can
    Lined with 1" kaowool
    Rigidized
    Camp-stove propane cylinder crucible
    Fired it up
    Poured an ingot(ish) hahahaha
    Burner is forced air using a CPAP machine. Two inline propane regulators, simply because I was testing one I bought at a thrift store and threw it inline after my 30# one just because it has the only tank adapter I own.
    Happy melting folks!
    Mburtis, Tops and Tobho Mott like this.
  11. FishbonzWV
    Bucket forks 2.0
    Fixed some of the shortcomings on the forks. I had built them from pictures on the web.
    Without cross braces they just flopped around but I was able to pick up a couple parking blocks.
    Afterwards I found one the 1.5" standoff welds had cracked. Those were preexisting on the rails and I had just built off them.
    One of the 7/16" screw jacks bent from too much gap.
    Hopefully these will work better. There's a log loading job next week.
  12. Rob Hall
    How'd this hold up? I've been leery of these clamp-on things for my front end loader. I cannot see those welds holding any kind of weight. I would love to have some kind of pallet forks I can gather logs with on my property but I find it hard to believe those joints hold 2000#
  13. FishbonzWV
    Didn't get to use them yet. The guy that wants the logs hasn't shown up. I was going to let them rot.
    I have no intention of trying a ton of weight, just a couple 10' logs at a time to load his truck.
    I've been clearing a hillside with problem pines that were taking out the power lines when they had a snow load on them. Power Co. wouldn't take them down. If they did, they just leave them lay where they drop. I had to rig every one, pull it uphill, cut, de-limb and stack.
    Burned 4 slash piles over the winter, have another ready for tomorrow.
    I've become a hater of red pines, absolutely no root ball to keep them upright.
  14. FishbonzWV
    Bucket Forks 2.1
    I've been using the forks hard. Had a huge Oak uproot and cleaning up the mess.
    The jack screws were in the way and I bent them throwing logs into the bucket. They also inhibited dumping brush and logs out.
    Replaced them with short bolts. Another mod I would do would be to taper the rear of the arms.
    Jerad is 6'2".
  15. FishbonzWV
    Bucket forks redux:
    I've really given these things a workout.
    The tube under the bucket would bend and I would use the log splitter to straighten it.
    The last overload was moving a 6' x 8' pressure treated deck with 5 foot lengths of 3" pipe over the forks, then a set of precast concrete steps and lifting a 10' x 12' outbuilding to position and level it up.
    My welds held...yay!
    Replaced the tubes with 2" x 2" and moved the crossbar closer to the bucket. Paint's drying.
