Advise on Smooth Bars
Discussion in 'Metal casting projects' started by RichB007, Feb 17, 2021.
  1. RichB007
    RichB007 Copper
    Hi Experts
    My 2 Kg ish Brass bars are coming out with a varied amount of pitting and very rough top/bottom ,meaning endless grinding before i can polish.
    Im planning to move to Silver soon and i want to avoid this.
    I have tried picking up the hot mould after pouring and banging it on the work top using grips but it doesn't seem to work.
    is there another way??
    Perhaps with air pressure or coating the inner mould with something???
    My mould is good quality.
    Any Advise??
  2. Patrick-C
    Patrick-C Silver Banner Member
    Do you preheat your mold? That could help. How about degassing? Do you do that? Molten brass tends to get more bubbly the more you stir it.
    Does that mean you are using a pressurized mold? You could coat the mold with powdered graphite. That will sometimes help the surface finish.
    Patrick
  3. RichB007
    RichB007 Copper
    No pressurized mould. Its just a £30 mould that i pour the moultern brass into.
    What is a pressurized mould??
  4. RichB007
    RichB007 Copper
    I do preheat the mould for a few mins.
    I dont know about degassing.
    When the brass is melting i do stir it a bit and i suppose when i skim off the top it does to...
  5. RichB007
    RichB007 Copper
    Would the graphite help??
    Do you mean the dry lube for locks etc??
    Patrick-C likes this.
  6. Patrick-C
    A pressurized mold is a mold that is air pressurized, so that it fits to the mold. It is used in the die casting industry.
  7. RichB007
    RichB007 Copper
    pressurized mould sounds good. can you send a link so i know what im looking for
  8. Patrick-C
    Yes I mean that stuff. I use it all the time and it helps get a smother finish.
    Patrick
  9. Patrick-C
    I will look, they are not easy to find. I will send you a link when I get the chance.
    Patrick
  10. RichB007
    RichB007 Copper
  11. Patrick-C
  12. I'm guessing what you are referring to as bars we might call ingots?
    What are you fluxing your brass with?
    If you're pouring clean brass into steel molds you should be getting a pretty good finish.
  13. RichB007
    RichB007 Copper
    Yes Ingots. About 2kg a time.
    Im not fluxing.
    I just melt with an electric furnace electrical/plumbing brass or Objet d'art brass and pour into a mould.
  14. I melt scrap brass regularly and if I don't put some flux in it I get lots of slag. I use brass flux from Budget Casting Supply. It works well. I don't know about the UK.
  15. RichB007
    RichB007 Copper
    OK. Can you send me a link please so i know what to look for...
  16. rocco
  17. Jason
    Sounds like open face casting to me. What's the mould made of?
