Dog Sulpture Revisited.
Discussion in 'Lost wax casting' started by Mantrid, Jan 20, 2026.
  1. Mantrid
    Mantrid Silver
    Many years ago I cast this Bronze of a German Shepherd.
    Although I was happy with the Dog the rest I wasnt satisfied with. The bronze mass at the base of the hind legs was supposed to represent a water splash and the green slate base was the water the dog was running through. I had two castings of this dog unfinished so I thought I would try to improve the impression of the dog running through water.
    To do this I used the same green slate but carved, polished and waxed the stone base to look more like water. I also made it a more organic shape rather than the rectangle on the previous attempt.
    In addition to this I used a new white patina recipe I found maade with Tin Oxide and titanium dioxide. This produces a real intense white however it does not stick well to the bronze and a traditionl wax finish just soaks it up and makes a huge mess when you try to polish it. To resolve this the new sculpture has the water splash sealed with a clear acrylic coating while the rest has the usual bees wax finish that I prefer.
    Let me know if this is an Improvement.
    I have also been inspired by seeing glass casting videos and I am currently attempting to do a third version where the water and water splash will be cast in glass. I have already made moulds and have been experimenting with my metal melting gear with mixed results. What I have learnt is that you really need proper kiln with programmable temp control as glass cracks easily if a proper annealing process isnt followed. I hope to take a short introduction to glsss casting at a local place that also rents out kiln time in march sometime so hopefully should progress then
    Tops, OmniVarious, Rocketman and 3 others like this.
  2. FishbonzWV
    The oval base looks much better.
    Changing to glass...brilliant idea!
    If you can get the glass to work, working in mixed media takes it to a whole different level of artistic excellence.
    Mantrid likes this.
  3. Tobho Mott
    Oval water base and white patina looks great! Can't wait to se the glass version. I was surprised to learn we have several glass workshops around here that offer classes and shop time.
    Mantrid likes this.
  4. ESC
    ESC Silver
    The second looks great.
    I was going through some old files last night and passed over the one I sent to you of my Australian Cattle Dog "Blue" running in the local pond. It was almost the same look as your German Shephard. I think you had asked for shots of the splashing water.
    Mantrid likes this.
  5. Mantrid
    Mantrid Silver
    Yes I remember that
    Heres the actual pic I used.
  6. Mantrid
    Mantrid Silver
    got two more dogs ready in ceramic shell. Just need some good weather. The watersplash has been removed and rods (which will be threaded) are coming from the bottom of the back legs which will pass through holes in the glass and into a stone base. The whole base wont be glass
    I made two bases one with watersplash and one without for the bronzes of the dog with the bronze water splash. However Ive since used stone bases with these.
    I then made moulds of these to to cast them in glass
    pic below shows the dog with bronze water splash in placeto use as a template for the hole
    Below are the glass castings. They were very brittle and broke as I was cleaning off the investment
    This is the one with water splash. Clear glass for the water (wine bottle) white fritt for the splash. Again it broke on clean up
    I will need to learn a new skill and have access to a glass kiln to proceed with this project
  7. mihit
    mihit Copper
    You are quite right that glass needs to be annealed, and it needs to be done...s...l...o...w...l...y...
    In industry this is done on a conveyor through a lehr, and a glass bottle could take anything up to a couple of hours depending on thickness.
    Mantrid likes this.
  8. Mantrid
    Mantrid Silver
    If the glass thing doesnt work out there is clear resins that can be used instead. but mixing bronze with plastic just feels wrong to me
  9. Would borosilicate glass be less prone to stresses as it has a lower expansion co-efficient?.
    Mantrid likes this.
  10. mihit
    mihit Copper
    Depending on the thermal mass of your furnace, you could make a flask to fit inside, pour the mold, then put it all back in the furnace (turned off) to retard cooling as much as possible.
    Obviously borosilicate is usually flame worked/ blown. (And annealed, but on a much shorter schedule) I'm not sure how the stresses would set-up when being cast.
    This glass stuff is all getting interesting, I might have to pick up another hobby :rofl:
    Mantrid likes this.
  11. Mantrid
    Mantrid Silver
    Did a quick search about borosilicate glass.
    quote
    Borosilicate glass has a high melting range, typically from 1,500°C to over 1,700°C (around 2,700°F - 3,100°F), significantly hotter than regular soda-lime glass, due to its silica and boron content, allowing it to withstand extreme temperature changes, with softening points around 820°C and maximum working temperatures up to 500°C. Its low thermal expansion makes it ideal for labware, cookware, and industrial applications.
    Not sure I would be able to get it hot enough for it to flow into the mould
  12. Mantrid
    Mantrid Silver
    I did something like that. I built an enclosure out of insulated fire brick. Stuck my propane burner into it. Got it hot enough to for the glass to flow into the mould then put fire bricks over the inlet and outlet and let it cool down gradually. although I couldnt see any cracks in the glass it broke easily when digging out the investment. I think it needs to be held at a specific temp (soaking) before a controlled cooling.
    mihit likes this.
  13. I have heard of people slumping borosilicate in an electric kiln, the softening point is 850 to 900 degrees C (where it sags under it's own weight) which is worth testing out.
  14. Mantrid
    Mantrid Silver
    It may work. Theres alot of fine detail in the water splash not sure if it will be fluid enough to get into the bottom of that mould. But its something to consider.
    edit
    I suppose I could grind some up and pour into the water splash part of the mould as I did with the soda glass one above
  15. Mantrid
    Mantrid Silver
    edit
  16. Tobho Mott
    @Jason might have some pointers on annealing cast glass dos and don'ts. He posted about some glass lampshade bits he was making using different techniques on here a few years ago.
  17. OmniVarious
    OmniVarious Copper
    While the glass idea is a good one I would probably see if I could get my local glass blowing/manufacturing guy that has a studio 2 miles from me to do it. He stays pretty busy with multiple large orders for glass pipes and Christmas ornaments though.
    I like the dog statue!
  18. Mantrid
    Mantrid Silver
    had a break in the rain today so cast the two dogs without water splash and rods in its place.
    Started raining again just as I finished so good timing. Off skiing in march so be great to get some alpine sunshine instead of this depressing continuous cold rain.
    They look ok but wont know for sure until sand blasted. There was some bits rattling around in the shell after burnout so I think there will be a defect or two some where.
    If you are curious as to how this will fit together with the glass water cast and the stone base. The bottom of each hind leg has a kind of peg and rod cast in place. Pic below
    The larger cylindrical section will pass through the glass casting of the water splash and rest on the stone base. The thinner rod will be threaded and pass through a hole in the stone base and bolted on the other side. I bent the rods a bit and maybe the back legs when hammering off the shell. So I will have to heat them and straighten them up again.
    OmniVarious and Tobho Mott like this.
