Hello From Medford Oregon USA, 9KG Furnace Kit??
Discussion in 'New member introductions' started by DonF, Nov 15, 2024.
  1. DonF
    DonF Copper
    I have been looking at this site for a few months. I found it from a lost foam casting video on youtube by Kelly Coffield. I did cast a few things in aluminum in high school about 40 years ago, but havent done anything else.
    Last week I ordered this kit off Amazon to see if I could get the hang of sand casting once again. https://www.amazon.com/dp/B0CQP6VS9X is this kit OK? The reason I put it off was everyone on youtube and forums seemed to have a different opinion of what was a good starter set up. So last week I just bought something to get started. I haven't done anything but open the box just incase it was a mistake, but so far it looks to be fairly well thought out and if it's a keeper I think the next step is ordering the refractory cement to coat the inside?
  2. Tops
    Hi DonF, welcome to the forum.
    The tongs and pouring shank look nicer on that setup than the pliers that came with mine.
    If the burner inlet is not off to one side enough (tangential to crucible) the furnace may be slower to heat.
    The burner is seems to be missing a small sliding baffle to regulate air on the inlet , which could be rigged with a pipe nipple and a thumbscrew. I see than many do not have them any more online and some have a more elaborate baffle system.
    I coated the inside of mine with the wrong stuff but it stuck well enough to be serviceable.
    What are you hoping to cast? Are you thinking green sand or Petrobond?
    DonF likes this.
  3. Al2O3
    Welcome to the forum Don. I haven't seen that kit before but it seems like a reasonable price for all that is included. As you have noted, opinions will vary on whether it is ok. IMO, it really depends how often you will use it and what you intend to melt. Similar fiber blanket insulated units like the "Devil Forge" brand tend to be round but as long as the burner flame doesn't directly impinge on the crucible it probably doesn't matter much, especially for lower melt point alloys like aluminum. Besides stabilizing the fiber surface, coating the ceramic fiber with something like Satanite will make it more durable.
    Get yourself some PPE like a face shield, some welding gloves/apron, a bucket of sand, and do some lost foam casting.
    DonF and Tops like this.
  4. DonF
    DonF Copper
    I bought 50lbs of petrobond on ebay last night. I was going to cheap out and try kitty litter and fine sand, but I read where making sand that produces good results can be tricky. The plan is to store it in a 5 gallon bucket for now to keep it sealed up and clean. Thanks for the burner tips. I will try it as is but look for improving it soon. The burner is offset slightly to the rear of the furnace, but its pointed flush with the wall. I want to try casting a sand rammer first. It seems like a fairly easy project.
  5. DonF
    DonF Copper
  6. Tops
    I do like Petrobond as 'starter' sand, takes out a bunch of learning curve time in the beginning.
    As Kelly mentioned, lost foam is neat too, I was just making some foam patterns last night...
    A 12" (30cm) piece of 5/4 or 6/4 (32 or 38mm) hardwood with one end flat and one end looking like an oversized dull chisel /slotted screwdriver makes a nice smaller sized rammer. I use one like that more than the fancy wood one I ran out on the CNC...
    That Satanite looks about right. I used Mizzou which is a dense castable meant to be applied thicker and not as a wash.
    DonF likes this.
  7. DonF
    DonF Copper
    Thank you for the information, Tops! Castible Mizzou was what I had bookmarked before Kelly mentioned the other brand. Now I understand why castible was in all caps. I am glad I asked. I am not in a big rush. I would rather do it a little slower and learn from others advice. I did watch a few videos showing what the air adjustment sleeve does. I think I need to cobble up one soon. I have a lathe so that's an easy job if I happen to have some scrap that is close.
  8. Tops
    You are welcome Don! And remember, we like pictures of gear and project and stuff...:D
    DonF likes this.
  9. Tobho Mott
    Welcome! The tongs on the right look just like the ones we had for the induction melter at the blacksmith school where I worked.oaet time for a while. That furnace took small graphite crucibles with a flanged upper rim. The ring part of the tongs fit under that flange, and the little bent tab hooked over the top to ensure the crucible could not fall out even if tipped all the way over. Worked great for that style of crucible. But I'm not sure how a pouring tool like that could safely be used with a non-flange-rimmed crucible like the (presumably) clay graphite A-style crucible shown in the picture above. If you grab it high enough for the tab to hook over the top, you'd be holding it dangerously high up IMO with no flange to keep it from dropping out. I'm not sure if the picture is inaccurate or if they're giving you the wrong tongs / crucible type combination. A simple, suitable ring shank isn't that hard to build at least. The liftout tongs on the left however are possibly the best I've seen for one of these hobby kits. Every other kit I've seen comes pliers-like tongs meant to grip the rim of the crucible. Which is scary dangerous IMO.
    There are a couple good threads about crucible tools here worth checking out if you want a look at what tools others here use to move their glowing hot molten metal around.
    DonF likes this.
  10. DonF
    DonF Copper
    Thanks for the info Jeff. I checked the fit last night. It does hold the crucible high, and the crucible they sent doesn't look like the picture and has no taper until the last bottom third. Of course they are pliers so constant force has to be held on the two handles, but the diameter looks to grip well for the 6kg and 9kg graphite crucibles. I am just estimating from the OD measurements on the 6 as the 9 is all I have now but being pliers they have some range. The tab really isn't necessary as long as you are pushing the handles together, so if it's better to grab lower I can take that off? The furnace they sell in the 9kg kit has the same measurements as the 12kg kit. So I think the furnace could be used with a 12 kg crucible.
  11. DonF
    DonF Copper
  12. Al2O3
    It may be. Satanite is a Harbison Walker product. Mr Volcano is just the name of the Amazon seller. See attached. Technically, Satanite is a mortar, not a castable refractory.
    Just a point of clarification, Top's build uses Mizzou castable refractory and forms to cast/mold the furnace hot face. This is what I would call a traditional furnace build and what I was referring to when I mentioned opinions vary. Done well they can be very durable. Dense castable refractories like Mizzou "set" when mixed with water and undergo further changes when fired. They are not a good choice for diluting with water and use for brush coating a fiber surface.
    By contrast, Satanite can be readily thinned with water to a brushable consistency, then just air dries, but doesn't achieve its material properties until fired which can be done immediately after application, even when wet.
    Here's forum member Fishbones's Satanite fiber furnace build method.
    Propane tank/fueled furnace build | Page 2 | The Home Foundry
    Tobho Mott and DonF like this.
  13. DonF
    DonF Copper
    Thank you for the tips, Kelly! I will order some and hope for the best.
  14. Tops
    Kelly, my little Amazon furnace does have a coat of Mizzou, I did not understand the difference at the time and I could get it by the pound from the ceramics supply house before I became acquainted with the firebrick supply place a half mile down the road. They have since sold me Kastolite 30i for hot facing and Minro Z as a wash.
  15. r4z0r7o3
    r4z0r7o3 Silver Banner Member
    Welcome to the forum!
    Tip on PPE (credit goes to someone else here): I just got this chainsaw helmet, and indeed it does have a metal face-shield screen. You can unscrew the brackets holding on the ear-muffs and remove them to save weight. The headgear has a ratchet tightening mechanism on the back which seems reasonably well made for the price. About my only complaint is the face-shield doesn't protect my neck much, so I'm thinking of sewing on strips of (metal) window screen or similar.
    As an added bonus, replacement screens aren't very expensive either.
    DonF likes this.
  16. Al2O3
    Though they may share some materials, mortars and castables are different animals, and in general, mortars are meant to be applied in relatively thin layers, adhere to surfaces, and are composed to do so. Castables are not, and I wouldn't recommend interchanging their intended uses. I don't know about the last two listed above but no need to research them IMO if they are castables. No idea why a refractory supplier/pro would recommend a castable over a mortar for a coating application.
    People tend to focus on the potential health issues of fiber, but fact is, they make for a very poor furnace interior hot face, because once fired, it becomes quite fragile and much more friable. It's also more readily attacked by combustion gases, and though they are very good insulator, have low refractory for the task of a fuel fired furnace hot face, especially in and oil fired furnace.
  17. Petee716
    Welcome Don. That looks like a pretty decent starter kit. The other guys have touched on some pretty relevant stuff. You could get a couple inches of PVC of a close ID and open it up on the lathe to slide onto the burner tube to open or choke the air. Sometimes your burner may need adjustment as things heat up and it's nice to be able to adjust your air as well as fuel pressure. Once you get your feet wet you may want to add forced air, but that's a conversation for another day.
    As for youtube videos, if you see something that looks sketchy it probably is. Short pants, flip-flops, no face shield, etc.
    One thing alot of youtube guys seem to do is quench their castings. It's probably just for visual effect. There's nothing wrong with it in most instances, but it's unnecessary. Most aluminum is cool enough to handle in a half hour or so. But there is a real safety issue with water around molten metal in general. Anywhere water can be captured by molten metal it will flash to steam and pop drops or blobs of molten metal in the air and whatever it lands on (like your body, house, garage, dog) could very well end up on fire or with a hole in it. Most times you will have extra metal in the crucible that needs to be poured off into an ingot mold. Alot of folks use cupcake pans. Try to find one's with no teflon or else wire brush it off. It's quite toxic when burned. Always preheat your steel ingot molds over your furnace exhaust to red heat in order to drive off any moisture hiding under the oxide layer.
    Just a couple thoughts that came to mind.
    DonF, Tobho Mott, Tops and 1 other person like this.
  18. DonF
    DonF Copper
    Thank you all for the tips! Yes, I saw the muffin pans in a lot of videos online. Other forums say the muffin pans with two piece stampings (the cups are pressed in to the flat part and crimped) fail quickly if used for ingot molds. They also recommended finding pans without coating, like you did. So I started looking for once piece muffim pans with no coatings and this is the only one I found https://www.amazon.com/Fox-Run-Stainless-Muffin-Cupcake/dp/B0CXYM169J? I can weld my own ingot trays up if that would be better. Like everyone else though I already have too many projects so if the stainless steel muffin pan is a good choice, that's another project I don't have to make myself.
  19. Tops
    Sometimes the secondhand/charity shops will have used cookware stuff like that. Our local will sort through them and put ones 'not good enough' in a different spot to be used for crafts or part bins. Mine is a 3-egg poaching tray that got separated from its pan. I should be more systematic about preheating it well above the boiling point of water before I pull the molten crucible and pour metal.
    DonF likes this.
  20. Petee716
    The trouble with the crimped cupcake tins is that when you overflow the cup the aluminum finds its way under the crimp and solidifies. Then you end up prying or beating the ingots out and their condition and usefulness deteriorate rapidly. Outside of that, a good steel cupcake pan will last for years if it doesn’t get banged up and you don't leave it outside. The aluminum doesn’t stick at all, and the ingots are a convenient size and store well in a 5 gallon bucket. I pour extruded aluminum into dog food (and smaller) cans for lathe-turning blanks too. You just have to cut them out of the can.lol. Goodwill, yard sales, dirt-floor auction houses, etc.
    Thats just for aluminum though. Copper and copper alloys will either “weld” to it or burn through thin steel. Neither are gratifying, believe me. I have trays I’ve made out of angle iron for that. I ground the mill scale off of those when I made them and keep them outside so they’ve got a good coat of rust to keep the bronze from sticking. That might not be the best way, but that’s what I do.
    It seems like a trivial matter, but when you have a half of a crucible left over, you’ve got to do something with it!
    Tobho Mott, DonF and Tops like this.
