Latest experiment
Discussion in 'Sand Casting' started by AllenHanford, Mar 11, 2023.
  1. AllenHanford
    AllenHanford Copper
    Sawyer massey and Tops like this.
  2. Tops
    Tops Silver Banner Member
    Nice! What did you use for the patterns and core?
  3. AllenHanford
    AllenHanford Copper
    I made the pattern out of poplar. It was my 4th or 5th try because I went into this with the incorrect assumption that bodgy wood work was okay.
    For the core I split a piece of PVC pipe on the bandsaw. Then I held the pipe together with hose clamps and packed it with petrobond and some nails.
  4. AllenHanford
    AllenHanford Copper
  5. AllenHanford
    AllenHanford Copper
    This is the pattern I made. Pretty lame but it got the job done. I also machined the faces of it which revealed lots of tiny inclusions. No surprise since I didn't bother with degassing, although on one end it looked like the bubbles are radiating away from the core. I'll have to use hardened sand with a vent through it next time.
  6. There's nothing lame about a pattern if it works... as far as porosity goes, I've had castings so porous you could blow air through them like a sponge. Even GM Australia had to vacuum impregnate their V6 aluminium engine blocks with resin to seal them, it caused problems when using propane as the fuel. A faster melt time if possible can help as well as not casting too hot, the cooler the melt the less hydrogen gas can dissolve in it.
  7. AllenHanford
    AllenHanford Copper
    I feel like as the son of a shop teacher my woodworking should be a little slicker :D
    The porosity isn't anything that would affect functionality and there's plenty I will be doing in the future to improve it. Like knowing what temperature the metal is when I pour it, or getting the proper tools instead of using a pair of tongs for everything.
    I'm just really stoked that I got this all working. It's been tougher to get going than I had anticipated but it's super gratifying.
  8. Al2O3
    ....and so it begins.....you're hooked :)
    Enjoy the hobby.
