Spring crucibles.
Discussion in 'Foundry tools and flasks' started by woolstar, Mar 22, 2025.
  1. woolstar
    woolstar Copper
    A new batch of crucibles for summer melting plans. All random Amazon purchases:
    big one is a Nelyrho #15, medium Molten Masters #12, and small is CANALHOUT #2.
    We'll see how they hold up.
  2. Tops
    Please let us know how it goes.
    I have been considering the Nelyrho #15 or the OTOOLWORLD 20KG as they seem close to a Salamander A10 size-wise.
    Nelyrho Size: #15(20kg)
    Capacity: The capacity of the crucible is 2200ML. Max Copper-20kg.
    The inner diameter of the crucible is 135MM, the outer diameter is 165MM, and the height is 208MM.
    OTOOLWORLD 20KG Clay Graphite
    Capacity 2400ML
    H 22cm/8.7in x OD 18cm/7.1in x ID 14.5cm/5.7in
    Salamander Crucible "Super" A10 is a high quality Clay Graphite
    SPECIFICATIONS: - Working Capacity: 39 Lbs. / 18 Kgs Brass. - Overall Height: 7-7/8" / 200mm - Top Outside Diameter Width: 6-1/4" / 160mm - Bottom Base Outside Diameter: 4-3/8" / 110mm - Molten Capacity: 2.40 Liters - Crucible Weight: 6.4Lbs / 2.9Kg
