Adjustment for shrinkage
Discussion in 'Lost foam casting' started by Kent, Jan 9, 2023.
  1. Kent
    Kent Lead
    I’m looking to cast a base with 8 holes in it.
    How much will aluminum (A356) cast at a reasonable temperature 1350f shrink?
    If I just increase the size of the whole model will that be sufficient (ie is the shrinkage “linear” in all directions assuming uniform thickness….)
    I may just be over complicating things….. but everything I have ever cast that had features that “matter” I machined after rough casting. This time the item is too large for my mill.
  2. Kent
    Kent Lead
    I found the answer….
    Just watch a video from Al3O2 on YouTube…
    1.3%
    Thank you for sharing all the great content you do!
