Flying skull hood ornament
Discussion in 'Investment casting Ceramic shell method' started by DavidF, Apr 15, 2019.
  1. DavidF
    Started on making up some hood ornaments for a customer who carved the master pattern from a chunk of Corian. The mold is done and I'm pouring the waxes now. Will still be another week or so before I pour. Here is a picture of the first wax...
    Jason and Tobho Mott like this.
  2. Tobho Mott
    Hey, that's gonna look pretty cool! What metal does he want it cast in?
  3. DavidF
    Just aluminum...
  4. PatJ
    PatJ Silver Banner Member
    That's pretty neat.
    I think stuff like that goes from some good money at the car shows.
  5. Jason
    Jason Silver Banner Member
  6. DavidF
    Yes you can chrome plate aluminum, it just requires one more step in the process prior to the cyanide copper strike.
    The original ones were not plated, and this whole thing is about traditional hot rodding so plain old aluminum it is.....
  7. Jason
    If it was my rat rod, it'd be bronze. I'd polish his teeth and leave the rest flat.:D
  8. PatJ
    You could always anodize it.
    Apparently you can get a variety of colors and finishes.
  9. DavidF
    Cast aluminum does not anodize well due to the silicon content. They do make a special dye for cast, but as far as I know it only comes in black.
    These were originally polished, but I'm just pouring the castings....Well, I am making one for myself. I'll polish it....
  10. PatJ
    You could polish it and clear coat it.
  11. I've successfully anodized cast aluminium alloys with silicon, if you bead blast the surface or work it over with a wire wheel it then seems to anodize well. Probably the silicon gets removed from the surface by doing so, I was anodizing sand cast 90 degree elbows used to fabricate intake manifolds so there was no fine detail. A dip in a 20% nitric acid solution after polishing will brighten/whiten the aluminium and establish a thin uniform oxide layer as nitric is an oxidizing acid, you have to do that as the final treatment before anodizing (de-smutting).
