Furnace lid removal
Discussion in 'Furnaces and their construction' started by OMM, Sep 30, 2019.
  1. OMM
    OMM Silver Banner Member
    With some more thought about lid removal, I decided to make it a two-man lift, or a one man lift, or a notched handle that is a hinge. The angle iron is picking up 6 of the 10 bricks. There will be a hinging mechanism that will be locked on to the dog bone bar. The bars on each end are free spinning.
    Not a lot of time on my hands since, that thing work keeps getting in the way... but, I did have time to spin up these eight clamping clamping washers from stainless steel that are 3/4 diameter x 1” long, as I don’t want to weld if I want adjustablility. I drilled them out with letter “O” drill(0.316), and now I will mill them to be somewhat of a beam clamp for a 5/16 screw.
    Mark's castings and joe yard like this.
  2. joe yard
    joe yard Silver
    Matt
    The furnace is looking great. The light weight mobile design gives you many options.
    At this rate I would be surprised if you do not melt mettle before I do.
    i made it back out to the shop tonight.
    After air drying The sample was showing deformation at 10 Lb psi. The deformation was slight and cushioned. It was very light. I placed the 4 gram sample of wool + dried slurry in the heat treat oven and brought it up to 1800F
    After cooling the sample failed at just over 5 psi. When it failed it was a total failure that turned quickly to fine partials.
    I did not bring a scale nor camera tonight and the remains of the sample were promptly disposed of.
    I do have the non dissolved grog in a container. I will dry this out, weigh it to determine the total weight gain of the sample.
    I believe this would be a usable weight to compression ratio.
    After firing the material has poor abrasion resistance.
    I have made some progress on the burner slide and lid lift leaver assembly.
    It is now very close to ready for a test run.
    Before I plan on putting it into service I have to clean and modify a shed. It is the dreaded shed of quality stuff ... “junk”. I have been slowly digging my way down in the pile and found my old foundry bench. I hope to find a couple of flask in it. One less thing to build before getting started.
    Joe
  3. OMM
    Joe just keep plugging at it a little bit every day. That’s what I do. I somewhat finalized my lid opening device, and I wanted to update this thread. After my trial lighting, I might add a extension handle.
