Furnace struggling to melt copper, help needed.
Discussion in 'Furnaces and their construction' started by Conor, Feb 24, 2025.
  1. Conor
    Conor Lead
    Hi all,
    I'm sure this is a really simple question to some, I am aware I don't understand some basic principles of air/fuel ratios and how it produces heat. I'm hoping someone can help me.
    I have a VEVOR propane furnace and every time I adjust the choke on the burner more than one hole, the thing starts to sputter and becomes unusable. My gas pressure usually between 10-15 PSI (but sputtering continues no matter what way I adjust the PSI). So this system is OK, and will melt tin bronze fine, so it obviously reaches bronze melting point easily enough. But today I had about a kilo of copper and after more than an hour, it still hadn't melted. So my thoughts are that it was struggling to reach a certain temperature. I increased the PSI up to 25 but still couldn't adjust air flow so I think I was just wasting fuel. Maybe if my furnace allowed me to increase air intake beyond a certain point, melts would be much quicker? Or maybe it doesn't work that way.
    Maybe my copper was alloyed with something else making it harder to melt, although I doubt it as it was scraps from the jewelry dept in art college and was told it was 100% copper.
  2. Tobho Mott
    Some close up pictures of your burner might help. I'm a forced air burner user, so take the rest with a grain of salt.
    It might help to keep experimenting with making just small adjustments to the gas (and air intake if necessary) once you have it running stable/neutral. Within a certain range of gas pressures, you may not have to adjust the air intake (much?) to turn the heat up or down without changing the mixture significantly, since more/less gas flowing into the venturi should suck more/less air in with it. (I think. Again, I use a controllable blower)
    In theory, if you have the right mixture, more air and gas at the same ratio should heat things up faster. At least up to a point. Likewise, the wrong mixture may cool things off.
    I'm not sure what pressures yours is designed to run best at, you might be able to find a sweet spot if you keep playing around with it. Ideally you want to hit pretty close to neutral. The way I identify that is when the flames completely fill the furnace without really coming up through the vent hole in the lid more than just a little bit.
    Good luck,
  3. DavidF
    You should add forced air to it, it'll do the trick. I use a hair dryer on low and I'm able to melt cast iron.
    HT1 likes this.
  4. HT1
    Which Vevor furnace do you have???
  5. Petee716
    Petee716 Gold
    Wondering if the propane tank is freezing.
