Hello, hobby casting from Seattle area for a recumbent motorcycle project
Discussion in 'New member introductions' started by Matus, Nov 27, 2022.
  1. Matus
    Matus Copper
    Hello casters!
    I did my first casting quite a few years ago now. I do lost foam casting and make parts for a recumbent motorcycle project I've been working on:
    It's not weight or performance optimized and is just the first phase of multiple stages to test out the geometry and behavior. I plan to build an optimized version with all new components after testing and refining the prototype.
    Those rear wheel mounting points and the rear wheel hub were all cast by me and then machined.
    In troubleshooting some casting failures I came across Kelly's videos and thus this forum.
    Looking forward to learning many great things here and improving my casting skills!
    Tobho Mott, BattyZ and Tops like this.
  2. Tops
    That looks like one 'bad Moto Guzzi'...or is it? I am filled with chagrin as my 'good' motorcycle sitting in pieces in the garage.
    Welcome to the forum!
  3. Matus
    Matus Copper
    Thanks for the welcome! Just browsing around for a few minutes and I'm shocked at the complexity of things people are casting with lost foam. I definitely have much to learn to move away from my thick bulky disks and blocks.
    It's actually a Honda CX500, I think those are the only transverse v-twins, I think Honda copied the idea from the guzzis from the 60's. I'd love to put a guzzi v-1000 in this thing. I also have a turbo 650 version of that honda motor that puts out 100 HP from a rare cx650 turbo that I plan on upgrading this one too, but I'm going to test on the 500cc 45hp motor first.
  4. Al2O3
    Have you built and driven other motorized incumbents?
  5. Matus
    Matus Copper
    Nope this is my first one, there aren't many out there and just a few people building them.
  6. Al2O3
    I used to race motorcycles..........and I'm scared!
    K
  7. Al2O3
    It's a cool project Matus. Just a word of caution about hobby casting. In general, the material properties of castings will be poor compared to their wrought alloy cousins, especially so in the "as cast" condition and cast in a hobby environment. Many alloys will need post heat treatment to achieve expected strength. Castings can have hidden flaws that can dramatically affect strength. As a hobby caster, the quality and control of your melt, the source of metal, and the design of the part are all important contribruting factors.
    All of this is true even for commercial/pros but they will (destructively) test, and develop process........we usually make one. I've cast a few critically stress parts for myself and close knowledgeable friends, but in general, I will not. I'm happy to offer you advice on how to cast a particular part, but my advice would be to make your critically stressed parts like triple tree clamps, drive train parts, from wrought stock.
    When I was kid, if something didn't have an engine on it I thought it must have been an oversight and put one on there. If it already had one, I figured it needed a bigger one and immediately corrected the matter. I always ran with scissors. :)
    Now disclaimers aside, looking at your project, for someone who is building but never driven a recumbent motorcycle and considering adding a boosted V-twin, this is probably the least of your worries LoL!
    Welcome to the nuthouse Matus.
  8. Matus
    Matus Copper
    Thanks!! Oh yeah, I'm definitely aware of the severe limitations of castings - especially the ones that I do! I have a healthy sense of self preservation and, I think, being very cautious at every step.
    This is the approach I'm taking:
    - I'm massively over-engineering any cast part, I'm guessing a very low tensile strength of about 10,000 psi, which is like 1/4 that of the lowest common cast alloys you can get from a foundry, and putting a wild safety factor on top of that, at least 8 and often higher over max potential loads, and running FEA simulations in SolidWorks for each aluminum part.
    - I'll stress test my sprues / runners to get an idea of the tensile strength each specific actual casting has, machining them to a 1" cross section and then using a strain gauges actually measure their real tensile strength. Hopefully 2 or 3 samples per part, and re-calculate the FOS for each part based on that.
    - I'll also be calculating the density of each part by measuring the volume (since they are machined and simple shapes this is easier and extremely accurate) and the weight to get a rough idea if their are any significant voids in the structure
    - Most of the parts have either a second backup piece or are backed up with a separate steel part that 'limits' the extent of the failure hopefully enough that I can stop safely.
    - Last I'll be replacing each part in the near future with a legitimate machined from billet part as money permits, to reduce the risks of fatigue failures. Costs have dropped dramatically for custom machined parts I've recently found, even with short lead times, so this is becoming more of an option. I may end up doing this with that hub I posted about since it is now much cheaper than even a year ago.
    - I'm definitely not casting my own triple trees or anything like a aluminum twin spar frame!
    I don't think too hard to make a safe part if you don't care about weight :) For instance that wheel hub, it connects the sprocket to the wheel, has a FOS of 8 over the full engine output at max torque with the wheel prevented from slipping and the vehicle unable to even move, as if you bolted it to a concrete block and applied the max engine torque to it! In reality all it needs to do is overcome wheel slip torque. And it's only half the hub, the other side has a similar part and connects to the rear brake rotor. Both of those spin around a massive 2" diameter steel spindle. If both sides of that hub failed, the wheel spindle will still easily handle the weight of the back until I come to a stop. Most of the parts I'm casting though are more simple bearing and axle spacers that get loaded almost entirely in compression.
    I'm similarly progressing the bike design itself in stages, starting with a simple hard tail low powered chain drive to test the general behavior and geometry out, and I'll be adding additional complexity in phases after successful testing of any previous phase. You can learn more about the design and goals at www.matus1976.com or my youtube channel at https://www.youtube.com/matus1976
    My assessment is that once you start trying to optimize for weight and performance you start pushing boundries and riding at the edge of low safety factors, or using materials that suddenly catastrophically fail like carbon fiber as critical structural components, that's when you start really pushing your luck. When I get to that point, I'll be redesigning the entire bike from the ground up integrating everything I've learned and using all new high end components and professional engineers and fabricators to make a production model.
    Hope that makes more sense and makes it sound less crazy, I definitely welcome constructive feedback.
    Matus
