Test casting Frozen area of failure New design Latest casting showing successful pipestem and not invested body interior
Thanks, it's silicon bronze. Probably a very high silicon bronze considering how much of the crucible has melted into the metal over time (I reuse bad castings a lot) Once my process is refined and consistent I will do a couple limited runs in silver.
First success! I got one bowl and two stems from this casting session. The one on the left still did not invest properly. I fault that to the undercut "bowl" area making air impossible to escape. The one on the right came out! It better, it's just a simple elbow... I made the cavity 3/4" to accommodate a hardwood dowel bowl I will insert. Two stems are mostly hollow with a solid section in the middle. Should be a piece of cake drilling those out. Time to start the artwork stage..
