Mig welder? Should I have a look / Buy it?
Discussion in 'General foundry chat' started by Zapins, Feb 12, 2018.
  1. Zapins
    Zapins Silver
    There's a guy at my work who makes dune buggies. He has a hobart 140 that he's had for around 4 years now. He upgraded to a hobart 190 so he can do thicker welds and he wants to sell the 140. He says it still works and can give me a demo/show me how to use it. I think it comes with a regulator and the gun/tips etc. He wants $200 for it. Should I go have a look? Seems like a decent price for a used one, but I don't know how much life these 140's have in them? Are they like my syncrowave tig with 30+ year life spans or are they going to crap out after a few weeks in my hands?
  2. DavidF
    They are hardy, and thats a great price.
  3. Jason
    Jason Silver Banner Member
    Can't go wrong for only 200bucks.. 400? NOPE. Not even 300 for a hobart. Once upon a time it was a great brand. All chinese stuff these days. Sad state of reality. I found my next mig machine, now if only I can convince the wife to let me have it.
    http://www.usaweld.com/Pro-Pulse-200-MIG-Welder-s/698.htm
  4. OCD
    OCD Silver Banner Member
    You plan on doing some "Splatter" art Jason? ;)
  5. Zapins
    Zapins Silver
    Sounds good. I'll plan to go see it soon.
    Quick question with this. It states it can do 1/4" max steel. That means 1/4" in one pass correct? So if I want to do a 1 " plate for some crazy reason I'd need to put at least 4 beads to fill it (probably more). Right?
  6. Jason
    In a perfect world, yes one pass. At 140amps, 1/4" plate starts looking pretty fat to me. 1" plate, good luck with that. The problem is 140amps is not a lot of amps. If you go check that welder out, bring some clean plate and tell the seller you need a test drive.
  7. Zapins
    Zapins Silver
    Yeah that's what I plan to do. Problem is I will likely need to weld up to 1/2" at least to finish my wetsaw in decent time (the vice/apron). So if I can layer it up slowly that would work. Otherwise I could use the tig but it will put a ton of heat into the part and potentially warp it. Alternatively I could just wait and buy a proper 190 or 210 hobart later on if I can save up the cash but the hobart 140 might be a decent stop gap until then? At least better than the wire feed fluxcore one I borrowed from a friend.
  8. OCD
    If the machine is only rated for 1/4" that's it.
    There's no "multipass" to get it to weld thicker material, especially material twice as thick.
    If it's rated for 1/4" then that's all it can do to properly fuse the 2 pieces of metal together.
    You might get away with preheating the metal but like you said, it would start moving on ya because of the amount of heat that would be needed to work.
  9. DavidF
    HUH?? why not?? Thought it was pretty common practice to V it out and lay multiple welds to build it back. If not then I have been doing it wrong for years....
  10. Jason
    Don't mind John.. He's been breathing R134a all day working on an AC system. :(
  11. OCD
    Good Morning Class,
    That's to fill it, not fuse it.
    Can the machine in question fuse it properly in a single pass?
    Answer: No
    Why? Because it can't produce enough energy (amps).
    Simply put, welding metal outside of the machines abilities would be like trying to metal iron with a Bic Lighter.
  12. Al2O3
    Multiple pass welding is common. Don't tell Red97, that pour guy wont be able to repair his 400 ton press frames any more. Ever been to a ship yard and watch them weld 6-12" plate? or how steel castings are welded into the frame of a 400 ton mining dump truck?
    Red97 likes this.
  13. Red97
    Red97 Copper Banner Member
    A multiple pass fillet weld will provide acceptable results on 1/2" material.
    Will you have to use the max aperage/ test the duty cycle. Yes probably.
    Woul guess the duty cycle is 60% maybe 80%
    6 out of 10 min run time it will get hot/ shut down to protect itself when running at/ above rated capacity.
    Good solid little units, if it has been stored/cared for at all. That is a good price for a little machine.
  14. OCD
    Red isn't fusing 2 pieces of metal together, he's filling in voids in.
    Come on guys
    It's all about fusion and to get that fusion you need X amount of amps for it to do it's thing properly, otherwise your just melting filler wire/rod on the surface.
    I guess Lincoln is incorrect as well then.
    Weld Fusion vs. Weld Penetration
    I have heard some people say that with all welding, you must have deep or maximum penetration into the base plate in order for a weld to be strong. If you have shallow penetration, the weld is weaker. The deepest possible weld penetration is always best. Are these statements accurate?
    No, it is not accurate to say in all cases that an increase in weld penetration directly correlates to an increase in weld strength (where "strength" is referring to the weld’s yield strength and ultimate tensile strength, both measured in pounds per square inch (psi), kilo psi (ksi) or megapascals (MPa). A weld’s strength is determined by achieving complete fusion and by other factors, depending on the type of weld. This question merits a discussion of the differences between weld “fusion” and weld "penetration". To keep the article fairly short, the discussion will be limited to arc welding, two common types of weld joints (T and butt) and two common types of welds (fillet and groove). See examples in Figure 1.
    Figure 1: Commmon Joint and Weld Types
    Arc welding is taking two or more separate pieces of metal and joining them into one continuous or homogeneous section. You achieve coalescence, which means to blend or come together. In other words, the purpose of arc welding is to achieve fusion between the initially separate pieces of metal. The American Welding Society (AWS) defines fusion as "The melting together of filler metal and base metal (substrate), or of base metal only which results in coalescence" (ANSI / AWS A3.0 Standard Welding Terms and Definitions). Fusion occurs when you have atomic bonding of the metals. The molecules of each separate piece of metal and the filler metal bond together when you have 1) atomic cleanliness and 2) atomic closeness (see Figure 2). This occurs with arc welding such that the atoms of each piece of metal bond together with shared electrons to become one solid or homogeneous piece of metal.
    Figure 2: Atomic Bonding
    Now on the other hand, penetration, or properly termed depth of fusion, is defined by AWS as, “The distance that fusion extends into the base metal or previous pass from the surface melted during welding”. A cross section of a weld (particularly when etched) will show you the penetration profile of the weld, including the depth and width of penetration (see examples in Figures 3 and 4, which also name and highlight the various parts of a fillet and groove weld). To achieve the proper weld strength, all welding requires complete fusion to occur between the pieces of metal and filler metal, but not all joints require a large depth of fusion or deep penetration. As long as you have achieved complete fusion between the filler metal and the base plates (and when appropriate, the steel backing bar), you have successfully joined the metal together into one homogenous piece. It does not matter if you have deep penetration or shallow penetration. Theoretically (but not realistically), you could even have complete fusion to just the depth of a few molecules and still have welded the pieces together.
    As an example, refer to the T joint and fillet weld in Figure 3. The required weld strength is achieved by having complete fusion and by producing the proper fillet weld size (measured by either the leg length or theoretical throat length) for a given weldment. The appropriate weld size needed to achieve adequate weld strength is determined by the design engineer during the design stage. How this is determined is beyond the scope of this article. However, as the fabricator, as long as you make the proper sized weld per the design specification and achieve complete fusion between the filler metal and base plates, including the root, you have produced a weld of sufficient strength. Weld strength is not determined by the level of penetration into the base plates.
    Figure 3: Parts of a Fillet Weld
    As another example, refer to the butt joint and complete joint penetration (CJP) single V groove weld in Figure 4. Proper weld strength for a CJP groove weld is achieved by having complete weld fusion and by using the correct strength filler metal (i.e., one that is of at least matching strength to the base metal). Again, weld strength is not determined by the level of penetration into the base plates.
    Note also that with a CJP groove weld, the size of the weld does not determine weld strength either, as it does with a fillet weld. Rather, weld size is simply the resulting volume of weld metal necessary to fill in the joint of the proper dimensions (i.e., the degrees of the bevel angle or included angle and width of root opening). Proper joint dimensions are those which allow enough access of the electrode into the joint so that good welding techniques can be used to achieve complete fusion with the base plates (and steel backing bar). In addition, proper joint dimensions are necessary to ensure that the root pass has the correct depth to width ratio (discussed later in this article).
  15. OCD
    Figure 4: Parts of a Groove Weld
    The need to achieve complete fusion has been emphasized in this article. That is because a problem can arise if you have a lack of fusion in any part of the joint. This can be a discontinuity with the sidewall fusion, properly termed joint penetration, or fusion at the root, properly termed root penetration. Incomplete fusion can become a weld defect area, which can affect the weld strength and ultimately lead to weld failure. Figure 5 shows examples of acceptable and unacceptable weld profiles.
    Figure 5: Fillet Weld Profiles
    While not necessarily related to weld strength, there are situations in which deeper weld penetration can be beneficial. Here are three examples:
    Benefit: As stated earlier, you must achieve complete fusion at the root of a weld joint. If the electrode is not aimed properly at the root, the arc length or contact tip to work distance (CTWD) is not held at a consistent distance and/or proper procedures or set up are not used, then lack of fusion issues at the root are more likely to occur. These factors are controlled by the operator’s welding skills, with less experienced welders more likely to have lack of fusion issues. When you have a welding procedure that produces a deeper weld penetration (and a resulting wider penetration profile), you increase the chances of still achieving complete fusion at the root, even with welders that have limited skills. A deeper and broader penetration profile covers a bigger area. Thus you are more likely to still hit the root (i.e., achieve fusion) even if the arc is not focused directly at it.
    Benefit: Figure 6 shows examples of CJP groove welds in a butt joint with a root face dimension (i.e., the square edge or non-beveled portion of the plate edges in a butt joint). These joints will be welded from the first side (with one or more passes, depending on plate thickness). Then typically the weldment is flipped over and welded from the second side (again, with one or more passes). To achieve complete joint penetration, the plates must be beveled, as in the double V joint shown in the top picture. Or if it is a square edge joint (shown in bottom picture), then after the first side is welded, the second side of joint must first be back gouged to sound weld metal. Then the second side is welded. If welding procedures that produced a deeper weld penetration were used, then the depth of the joint bevels would not need to be as deep, making the root face longer. Or in the case of square edges, not as much base plate on the second side would need to be removed by back gouging before sound weld metal was reached. In either case, the volume of weld metal required to fill the joint would be reduced. This reduces both the amount of filler metal required to fill the joint and the welding time. Less welding would also reduce potential plate warpage issues.
    Figure 6: Joints Requiring Penetration
    Benefit: For fillet welds with a flat face and even leg sizes, the distance from the weld face to the root is called the theoretical throat. If you achieve fusion beyond the root, then the actual or effective throat length increases (see Figure 3 for identification of the theoretical and actual throats). Generally no design credit of extra weld strength is given for normal root penetration. However, if significant and consistent root penetration can be achieved, which significantly increases the effective throat depth, then the fillet leg size can be reduced without sacrificing weld strength (see example in Figure 7). Deeper weld penetration does not produce a fillet weld with more weld strength. Rather, it allows a smaller fillet weld to be made with the same strength level as a larger fillet weld made with less weld penetration. Smaller fillet welds decrease the amount of weld metal needed, and may even allow for increased travel speeds. This benefit could be potentially realized by using the Submerged Arc Welding (SAW) process, known for its deep penetration capabilities. Other arc welding processes can be capable of achieving deep penetration as well. However, the fabrication shop must be capable of producing the deeper penetration level on a consistent basis, so this concept may not always be applicable. This Welding Innovations article from the James F. Lincoln Foundation website discusses this topic in more detail.
    Figure 7: Greater Effective Throat Produced with Significantly Deeper Weld Penetration
    There are also situations in which deeper weld penetration can be detrimental. Here are three examples:
    Limitation: Deep penetration can be troublesome when burn through is a concern. When welding on thin material, such as gauge thickness sheet metal, too much penetration can cause the weld to burn all the way through the joint and fall out the bottom. In other cases, a thin root pass is made in an open root joint (e.g., pipe joint). If the second pass has too much penetration, burning through the root pass can be an issue.
    Limitation: If penetration is too deep, centerline cracking (a form of hot cracking) may become an issue. See Figure 8 for an example of a centerline crack in a fillet weld. A balance must be maintained between the depth of penetration and the width of the root pass. The depth to width ratio (W/D ratio) should not exceed 1 to 1.2. This keeps the shape of the weld fairly uniform. As the weld metal solidifies, the shrinkage stresses are thus fairly uniform in all directions. However, if the weld is significantly deeper than wide, then the shrinkage stresses are unequal and the weld will crack in the center of the bead as a result.
    Figure 8: Deep Penetration Weld with Centerline Crack Due to Insufficient W/D Ratio
    Limitation: Too much admixture with the base plate may also be a problem with deep penetration welds. As penetration increases, so does the volume of base plate that is melted and combined with the filler metal in the resulting weld puddle. This can possibly add additional elements into the weld puddle that makes the weld more crack sensitive. Examples would include welding on free machining grades of steel with higher levels of sulfur, phosphorus and/or lead. These softer elements have lower melting (and solidification) temperatures than steel. So in the liquid weld puddle, they tend to migrate to the center of the weld where they are the last elements to solidify. This high concentration of softer elements in the center of the weld bead often leads to centerline cracking from the solidification shrinkage stresses of the weld.
    Additionally, in the case of hardfacing or overlay applications, deeper penetration may dilute the weld deposit chemistry and potentially decrease its resulting wear resistance properties. Overlay welds are simply "bead on plate" welds. Figure 9 shows a weld overlay with minimum penetration and thus minimum admixture between the weld metal and base plate. Figure 10 shows a bead on plate weld with deeper penetration and thus much more admixture between the weld metal and base plate.
    Figure 9: Weld with Shallow Penetration
    Figure 10: Weld with Deep Penetration
  16. DavidF
    There's a reason I didnt add a welding section on the forum....:cool:
    Bottom line in my eyes is if the machine is in working condition, for $200.00 ya better jump on it!!
    Mister ED and Red97 like this.
  17. Jammer
    Jammer Moderator Staff Member Banner Member
    You do what you can with what you've got. Just don't try to weld landing gear for an airplane.
    Red97 likes this.
  18. Peedee
    Peedee Copper
    My dad used to 'fuse' 6"and up thick walled pipe 4 - 6 feet in diameter, boxes of rods, I guess they thought it was 'good enough' for mere petrochem refinery stuff ;)
  19. OCD
    Agree & Agree
  20. Zapins
    Zapins Silver
    Boys and girls (are there any on the forum?), I bought the hobart 140. Tested it out and it welds nicely. I even got a free regulator and a free older model auto darkening helmet for $200. Also got the box for the hobart 210 welder that he upgraded to. Bonus box!
    I need to pick up a 25/75 tank and then I'll be good to start welding.
    Only damage seems to be the trigger on the gun needs a pin to work perfectly, but a zip tie works for now.
