New Burner Ejector Style
Discussion in 'Burners and their construction' started by oldironfarmer, Jan 14, 2019.
  1. oldironfarmer
    oldironfarmer Silver
    Got a friend who was shopping for burners for a forge, so I offered to build him one. I don't have a gas forge so I thought it was time to make a pattern. I like black walnut. Lineup dowels drilled and nozzle covering one.
    Paper line split
    Dowels made
    Painted and lettering added
    Two cast
    MIG tip installed. Manifold is turned far enough for tip to clear air holes.
    First burner finished.
    Tube is 1" 0.049 304 SS (what I had) with two 3/4" air holes.
    Fire time!!
    Nozzle has no step, just the 0.049 wall thickness, I need to make a larger step nozzle.
  2. Jason
    Jason Gold Banner Member
    Looks good Andy. Let me know when you can make it run on natural gas.
    I hate hauling propane and bitch at the price every time I have to.
  3. Zapins
    Zapins Silver
    Really nicely done. Very nice looking parts. I'm sure it will work well.
    Why does everyone seem to want to forge and black smith these days?
  4. Jason
    Forged in fire I suppose. I haven't watched that show since season 2. Frankly I'm sick of reality tv bs. Our TV lives on TCM these days.
  5. oldironfarmer
    I've been blacksmithing for thirty years or so, but with a coal forge, like my friend. We both would like to have a gas forge for various reasons. However I think the Forged in Fire series is a good thing, more people are interested.
    Jason: I expect to build a natural gas burner. I don't have gas service but have a pipeline across my property. They have offered me a farm tap (free gas:D) in exchange for a right of way on some other property. So I may be getting into gas in a big way: foundry, forge, shop heat, heat treating, etc.:eek:
  6. Jason
    FREE GAS? I'd build a huge shop and keep it 80degrees in that sucker!
  7. _Jason
    _Jason Silver
    And that, right there, is why it's so useful to be able to cast metal at home. You can make darn near anything you want.
  8. PatJ
    PatJ Silver Banner Member
    A cast burner body.
    Now how cool is that?
  9. oldironfarmer
    OK, now you can take a break from bifilm theory and help me. I should know the answer but it is not clear to me. I cast the first two burner manifolds perfectly. The third one however had a big shrink spot. The next two, (pictured) also cast well. Did I have the shrunk one just too hot? Or too cold so it didn't feed from the sprue? Surely the missing sand off the end did not cause the shrink, or did it?
    By the way, if anybody would like one of these they're pretty cheap.
  10. DavidF
    Not sure of the cause, but a little bit of bacindpot usually fixes it...
  11. oldironfarmer
    I'm not certain I have any of that. Could I substitute bacindapot?
  12. PatJ
    My guess:
    Your gate solidified before the part, and so the part became the riser.
    I would add a riser at the boss where the gas valve goes.
    See Rule 6:
    http://www.atlasfdry.com/rule6.htm
  13. DavidF
    Sure can, try the remeltum-dicrapum it works just as well....
  14. oldironfarmer
    Thanks for your insight.
  15. Chazza
    Chazza Copper
    Am I right in assuming these are cast in aluminium Andy?
    I have most shrinkage problems when the metal is too hot.
    The missing sand off the end may have been part of the problem as well, as it increases the volume of metal down that end.
    I did four identical small-castings recently, from the same crucible, at the same time; No. 1, 3 and 4 were perfect but No. 2 shrank! It can be quite maddening sometimes.
    I need to make a pyrometer, so that I can eliminate one variable,
    Cheers Charlie
  16. oldironfarmer
    Yes, scrap aluminum of unknown metallurgy.
    I have an immersion thermocouple but get lazy when everything goes well.:rolleyes:
