Sand casting an odd shape - sprue, runner, gates and risers
Discussion in 'Sand Casting' started by Ando, May 13, 2024.
  1. Ando
    Ando Copper
    Very interesting project MHJ and very helpful to see your techniques in action.
    Thats a good result on such a deep drag. I did think of adding support battens like yours but I'm using green sand and was worried the timber may pull out moisture and cause a drop out (still had plenty of drop outs)
    Each pattern sat on supports/wedges to keep them from moving during ramming. Pic below is of the last board with matching part of the styrofoam maquette on it. I've been following Jeff's thread; he did mention your patterns dropping out, so I took extra precautions.
    As with your project, each was recast in plaster for ramming up. Only one pattern cracked during ramming, though the jute cloth reo kept it together well.
    The two end pieces (pic) had no reinforcing jute in them so I just had to hold my breath while very carefully ramming.
    All pieces will be cleaned up and TIG welded (4043 filler), then I'll use a tungsten blade (meat axe) to facet some areas and blending wheel to clean the rest. I'll also bead blast the exterior to finish off. Happy days...
  2. Instead of using shims and supports, I am doing a pack of sand under the majority of my piece to stabilize it. Spreads the load. It acts as a partial false cope that I then remove before I ram the true cope.
    Mine will be TIGged together where the panels were cut to accomodate undercuts, but also welded to 6061 to make hollow blocks for assembly in the final sculpture.
    I am looking forward to seeing your final piece.
    Best
    David
    QUOTE="Ando, post: 53247, member: 9638"]Very interesting project MHJ and very helpful to see your techniques in action.
    View attachment 24372 [/QUOTE]
    Ando likes this.
  3. Tobho Mott
    Is that how you set up the piece above? I can see how that would have helped prevent the facing sand and first 20-odd scoops of sand from all just falling underneath the pattern when you were trying to load up the drag.
    But it's worth mentioning I did use shims to keep the bigger piece on Thursday from wobbling when I rammed up the drag (the first time). And on day 2 we also tried using some wooden blocks to support that one pattern that kept slipping. (Pics here: https://forums.thehomefoundry.org/index.php?threads/art-casting.2837/#post-53134 )
    :D
    Ando and Tops like this.
  4. Ando
    Ando Copper
    Hey Jeff and David, here's a pic of the four parts. Next step to trim/clean up, tack and weld.
    The exterior welds will be tiny, so as not to upset the look. I think I'll bead blast when complete to make the finish more uniform.
  5. Ando
    Ando Copper
    Process of turning the styrofoam to plaster patterns
    Hot wire cutting the original into four pieces
    Silicon applied to make negatives
    Plaster backing/removal of styrofoam piece
    Plaster positive in the mould
    20240427_155017.jpg 20240428_140557.jpg 20240430_111453.jpg 20240430_223403.jpg 20240501_095623.jpg
  6. cactusdreams
    cactusdreams Copper
    Good to know silicon doesn't stick to foam. Looks like it pulled very clean.
  7. Ando
    Ando Copper
    Yes and stretches to remove as well, so the plaster positive has that top edge/lip.
    There may be a way to stop the plaster sticking to the foam but the silicon picks up all that detail. (see the plaster positive in the last pic)
  8. FishbonzWV
    Ando,
    I've been following your post and excuse me if I've missed something but I'm wondering why if you are carving the pattern in foam that you just don't use lost foam casting to make the pieces. It seems to me that it would much easier, cheaper, and faster.
    Ando and Tobho Mott like this.
  9. rocco
    I'm not going to speak for Ando but I can think of at least a couple reasons for not using lost foam, first, this method gives you the option of making multiple identical copies, second, since all of the cast pieces are very irregular shapes and need to fit together, recreating the pattern for even one single failed lost foam casting would be very difficult, to the point you might need to start all over and re-sculpt and recast all of the pieces.
  10. Tobho Mott
    Even if you were somehow sure you'd fill every piece in one try, you'd have to be very careful not to flex the lost foam patterns enough during the burying process to ruin the alignment of the pieces as well. We know that is doable, but you'd have to be careful.
    My mind went there too when I saw the originals were styrofoam! ;)
    Ando likes this.
  11. Tops
    Wondering if a basic 2:1 no blush clear epoxy would work to coat the Styrofoam (EPS) originals to make them less porous and a tiny bit more rigid before silicone.
    I don't have silicone for molding but could make a test piece of foam with and without epoxy coating for someone to try.
    Ando likes this.
  12. Ando
    Ando Copper
    Hey all, I agonised for weeks over trying the lost foam method but just couldn't risk losing the original piece.
    Would not be a good look, phoning the artist...."umm sorry can go back and do another one"
    Haven't tried lost foam before so I thought I'd play it safe with green sand. I would definitely like to become proficient with the LF method in the future.
    The foam maquette was painted with several coats of water based polyurethane to seal it before it was laid up in silicone.
    I used supports to keep the original from flexing while applying the silicone and plaster.
    Epoxy resin was an option though I had the polyU on hand.
  13. Ando
    Ando Copper
    Just to wrap this thread; the project is complete. All sections welded and blended and the customer is very happy.
    I had intended in leaving the welds to the artist to take care of but she wanted me to make them blend in to the cast surface.
    I took the needles out of my needle gun, sharpened them to about 60 degrees and went to work. The action of deformation with the needle gun worked quite well.
    Pics don't do the blend justice, as they bring out the colour differential (not noticeable IRL) but if you look at the edge of the casting; that was ground flat then blended with the needle gun.
    Some partial pics here of the weld blends and the tool. 220240626_111923.jpg 20240625_183825.jpg 20240625_183835.jpg
    Tops, FishbonzWV and Tobho Mott like this.
