Ok, it's not a metal working project but here goes. 20 years ago, I built this bench. It’s 72”L x 25”W with a 5” skirt. My focus at the time was primarily woodworking. It had/has a twin-screw vise, holes for bench dogs, a pattern makers vice etc. For several years prior to the build, I tried to acquire some bowling alley lane for the bench top but was unsuccessful and eventually gave up and used what I had on hand which was some salvage maple and particle board I laminated to build it up to 2” thick for the bench surface and skirts. Now I knew at the time laminating particle board to maple wasn’t the best choice, but I did it anyway…..it was just a bench. For the first 15 years that bench lived in the basement shop of my previous home at very constant temperature and humidity. In those conditions it was dimensionally stable and stayed put. 5 Years ago I moved my residence and built a shop detached from my home. The bench took up residence in my new shop and although the new shop was heated, it was not quite as environmentally stable. Within two years in its new shop location, humidity changes and the various things that make wood move around through the Midwest seasons, pretty much made the bench surface self-destruct. The Maple and particle board didn’t take/give water from/to the air at the same rate and the Maple boards delaminated and cupped as much as ½” across 6-8” widths. It was fairly dramatic after previous 15 years of stability and faithful service. For me that made the bench surface almost worthless. I selectively soaked the bench top with wet rags and that very effectively flattened the Maple surface back to being manageable as far as flatness. I even sank a few drywall screws afterward at selective locations in the bench surface in an effort to slow the return of the cupping. However, within a few Winter weeks it was right back to being a total mess. After living with it for several years, I eventually got a great deal on a 72” x 36” x 1 3/4” laminated Maple slab with free delivery to boot. It sat still packaged in my garage for about 4 months until last weekend I finally decided enough was enough. With a couple lengthwise rips on the table saw I was able to use the extra 72” long by 11” of width to make all of the bench skirt from the single plank. Then after a little joinery, every clamp I owned was conscripted into service while I glued the skirt in place. After it set up for a day, I drove a big router and flush trim bit around the perimeter to true-up all the edges of the top to the skirt. It was starting to look like a bench top. I reused the twin screw vice hardware and jaws from the previous build and bored holes for the four T-bolts that anchor and secure the twin screw vice stationary jaw to the bench surface. I must say, it was hard for me to cut the mouse hole in the end of the solid Maple bench skirt for the pattern maker’s vice, but I use it too much not to permanently include it on the bench. Technically, I should not have added the reinforcing stringers across the grain because they will expand and contract differently due to grain direction. But the bench top floats on them so I think that will be minimal. Here it is completed. I have two pieces of 1/8” hardboard that were used to protect the maple surfaces during shipment. I’ll use those as everyday surface protectors for the next couple years and the bare Maple will only see the light of day for woodworking projects and pattern making. I haven’t drilled the bench dog holes in the surface yet. Figure I’ll do that when I need them. Sure is nice to have a flat true surface back on my workbench. I can’t believe I lived with it in the state of disrepair as long as I did. Best, Kelly
That turned out well. I have resorted to tossing a piece of 3/4" plywood over the top of my workbench, which was a green egg grille cart in its former life that someone tossed to the curb (I could not figure out why someone would cut a round hole in the top of such a nice table). It was in pretty good shape, and made from a quality wood, and with wheels, so I had to grab it and reuse it. It has made a good workbench, but I should probably add another layer of plywood. Those vices are priceless though. I may have to invest in some of those. That is a very solid unit. Well done. .
Looks great Kelly! No one who builds a quality bench is ever sorry with the exception of those who have let them go. I built my 2 primary work benches from cherry picked scrap yard steel over 20 years ago when I found a stack of 32x36 inch hardened ground flat .125 plate steel in a scrap yard. You cant dent it and although it is getting some age and rust is still very flat and close to indestructible. Lately I would like to say I have been working on foundry related items but I can not. I am on a crusade to fix maintain and restore every machine in the shop to proper working condition. Tonight 6 hours on a bent hydraulic press with 6 +/- to go then a new motor on the ventilation system and a month of cleaning and I will have the shop ready to use. Sometimes you look around and realize things are at critical mas. It is a case of pride and shame that I have posted limited pictures of the shop. After the spring cleaning that started a while back I will make a short video or at least take some pictures. I mean how long can it take to clean up after my self? I should have the mess cleaned before summer... If all goes well... The bench looks great Kelly. I wish I was talented enough to work with wood. God knows I have tried. Wood never forgives or forgets where metal can most likely be fixed or modified. As usual your workmanship is top notch! Joe
Very nice work as usual Kelly. We're the drawers unaffected? I feel for Joe. It seems as though I spend most of my time fixing stuff, cleaning up, or reorganizing clutter. I have a love/hate relationship with flat surfaces in my workshop. I have two 8' counters that I salvaged from a gutted retail store including the under-cabinets basically placed end to end for 16 linear feet. They are absolutely heaped with "good" junk.Ugh! There's nothing wrong with the counters or the stuff on them; I fear the problem might actually be me! I have a tablesaw that looks to be the same size as Kelly's with a sheet of plywood laid on. That serves as a bench when needed and I have a couple of small portable tables with tops around 14x20 or so, one steel and one wood, that I bang or weld on. Pete
Thanks for the comments guys. I suffer from the same symptoms......clutter, and over the course of time, having to choose working on projects versus clean up and equipment maintenance. Add time to the equation and it's easy to be overtaken. I used to be a lot more disciplined in balancing the two and more willing to throw stuff away. I have some things sitting on lateral surfaces in my shop that haven't moved for a couple years....that's just silly. My lumber rack is in a state of disarray and occupying twice the space it should. There's scraps of wood and metal growing in depth around my band saw. There are boxes of small jigs and fixtures from past projects that need to leave my shop area for a storage shelf and several pieces of seldom used equipment that have migrated into this portion of my shop that need to return to there original location. It's gotten to the point where I need to move things to use my machinery and then I usually get to move them again in short order. I finally decided I'm going to devote some time to clean up and organizing. The bench top was eating on me. It was cluttered and my table saw had become my surrogate bench, when the real bench was 5 feet away, but covered with crap and not flat. So the renewal of the bench top is a good first step. It had been a while since I did any significant woodworking. My memory got jogged on the shear volume of saw dust created. Everything in the shop was coated. On a positive note, I may be responding to my therapy. After staring at the old bench top and starting to think might be useful for something, I shook it off, took a circular saw to it, and in ten minutes reduced it to firewood in pieces < 6"x18" and transported the pieces out of my shop into my attached garage. Next stop....my fireplace. After I make a major dent in the clutter and get organized, I'm going to perform some additional equipment maintenance I've been putting off.....but if I get good weather this weekend, I'm going to take a shot at casting the that automotive upright....and maybe another intake manifold lid.... Yes, drawers were unaffected. The base and drawers are just as they were from the original build years ago. Like the first part of this post, the contents of the drawers need some attention. They're full. It's amazing how things take up residence in certain locations. As my primary bench, the only things that should be in those drawers are frequent use items. At this point, I'd say about 50% of the contents qualify. Best, Kelly
