Automotive Intake Manifold – Boss 302 Independent Runner
Discussion in 'Lost foam casting' started by Al2O3, Apr 24, 2021.
  1. DavidF
    Rotarysmp and BattyZ like this.
  2. Kelly,
    I am totally in awe of your talents. I'm so very excited to watch as this progresses to being a complete piece. Thank you for the videos of the process, it is very educational.
    John
  3. DaveZ
    DaveZ Copper
    That's some really AWESOME work!!
  4. Oldarm
    Oldarm Copper
    Absolutely SPLENDID! My heartiest congratulations. I followed your response to my suggestions and fully comprehend your comments. Thank you for taking the time out to explain your logic. It really is greatly appreciated. Apart from a little dabbling with the "white stuff" 50 years ago I have never explored the possibilities lost foam opens up. Now I see.
    John
    Rotarysmp likes this.
  5. BattyZ
    BattyZ Copper Banner Member
    NOICE!!
    Yes, yes, come to the dark side!
  6. Rotarysmp
    Rotarysmp Silver
  7. Al2O3
    Been a while but I made patterns for the air filter for this induction system. I've been learning CamBam, Gcode, getting acquainted with my CNC Router, and made this the pilot project for my first CNC’d lost foam patterns.
    72 Base Bottom.JPG 73 Base and Lid Top.JPG 74 Base and Lid Bottom.JPG 75 Filter Patterns On Intake.JPG
    Clay, Anders Lundholm, DavidF and 4 others like this.
  8. FishbonzWV
    Fabulous
    The sky's the limit!
  9. BattyZ
    Nice!! Are you doing manual bit changes? That chamfer looks dyno-mite. Looking forward to seeing the gating system for these pours.
  10. Al2O3
    Yes, manual. I had to break the Machine Ops into separate programs where a tool change was required. The top side of the lid required four tools. The other three sides 1-3. There were at least 3 different ways to make the chamfer. I just used a profile cut and specified the bit diameter as .001" so it cut on the center of the V-bit at my selected depth but there were several plugins available to do same and break edges.
    Yes, had that thought through while designing the parts. Besides feeding he part, it also needs to help keep the parts flat during molding.
  11. Kelly,
    The air cleaner came out fabulous! The detail work you are doing is just incredible. VVRROOOMMM! It is going to be terrific!
    John
  12. garyhlucas
    garyhlucas Silver
    Kelly,
    I don’t see any engraving. Piece of cake to add your name, logo etc.
  13. Al2O3
    Yes, that is on the near term list. I kind of like the wax applique I have but there is a clear polycarbonate lid I intend to cut and it will need to be engraved.
    I was reading on importing bitmaps for the more unique/custom artwork but I see I can download just about anything I want as far as logos. In general, what type of file is best/easiest to import that will allow you to insert and get right to it? Will probably use somewhere between a 1/16"-1/8" ball nose to do the deed.
  14. Al2O3
    Been a while since I updated the post. I know you guys like pictures so here they come. Gated the filter patterns…..
    76 Filter Gated.JPG 77 Filter Gated (2).JPG 78 Filter Gated.JPG 79 Filter Gated.JPG 80 Filter Gated.JPG
    Dip coated…..
    Dried overnight….
    Molded...
    Casting came out nice.....I like it when they look just like the pattern!
    Too tired to de-gate it today. -More to come.
  15. Al2O3
    More pictures! I cut the air filter casting apart separating the base from the lid.
    Then trimmed the remainder of the feed system off the base.
    I’ve learned not to get too aggressive on the table saw and leave myself ample room. I clamped both to the mill table and shaved the feed and support features down, then hit them with the small disc sander.
    They stayed remarkably flat….very pleased with that, but they could easily be straightened if needed as the castings are in a fairly soft state of temper. The shrink was right on and the interface features align very well.
    A one and done….thankfully.
    Ronny Bøe, FishbonzWV, DaveZ and 7 others like this.
  16. BattyZ
    That gating looks very well done, kudos!
  17. crazybillybob
    Kelly,
    That is some very pretty engine icing! I know I wouldn't kick out my garage! nicely done sir!!!
  18. Al2O3
    Thanks fellas. Did the finish machining and made the mounting hardware today. Just need to splice together a filter element and it’s done.
  19. Oldarm
    Oldarm Copper
  20. An issue where aluminum shrinks by about 3%. have you take it in molds or how do you handle it? Nice work you doing!!
