Casting defects...like warpage and shrikage
Discussion in 'Sand Casting' started by Arun, Oct 13, 2021.
  1. Arun
    Arun Lead
    Hello, i am working on sand casting for aluminium products....and i am getting lots of casting defects like shrinkage and warpage, shape deformation after solidification.... anyone one help me out this....that would be great.....!
    This above link is my casting defects video..... Can check....
  2. Smoking Shoe
    Smoking Shoe Silver
    From one lead to another:
    There is no simple answer. Spend a few weekends watching videos on YouTube starting here:
    Olfoundryman and others that have teaching styles that fit your learning style that you find along the way.
    Then come back here and do a search to answer any questions you may still have. ............which will be many. The more you learn the more you will find you still have left to learn.
    Without access to modern FEA simulations you just have to learn to think like hot metal. To corrupt a line from Caddyshack " Be the metal".
    Simple answer to the deformation you noted - move the riser closer to the gate to feed the shrinkage as the metal cools.
    Arun likes this.
  3. Arun
    Arun Lead
  4. Arun
    Arun Lead
    Thank u so much sir...for your help and guidance...
  5. Petee716
    Welcome to the forum. The link below will take you to the Navy Foundry Manual. It is an old manual but has guidance that will likely resolve your issues. (Gates and risers).
    https://maritime.org/doc/foundry/index.htm
    Arun likes this.
  6. Here is one of many YouTube links discussing riser use, directional solidification, and gating. Your initial attempt indicates a need to study some of the basics. I suspect many here may be reluctant to try recreate information widely available. No one video, blog, book, or website will contain all the nuances or necessarily be correct. But by spending time availing yourself of many sources of information, you will likely have more success and have more focused questions.
    Welcome to this forum. The learning curve on casting can seem pretty steep at first.
    Arun likes this.
