weird Petrobond sand recipe
Discussion in 'Sand Casting' started by HT1, Oct 11, 2020.
  1. dennis
    dennis Silver
    12-14$ for 5 ounces or so? I think that's what I paid when I bought a small jar at Blick's. (Art supply, downtown Portland)
  2. Melterskelter
  3. Mach
    Mach Silver
    Interesting, there is also something called Planter's Talc and graphite with talc added
    https://qualityfarmsupply.com/collections/planter-talc-graphite
  4. Jason
    Oh hell no. When I bought my jar, it was 80bucks..
    Look now!
  5. dennis
    dennis Silver
    Yep. Predation.
  6. Jason
    It's called capitalism. But I agree, it's a bit predatory.
    It is the blackest graphite I have ever seen.
  7. crazybillybob
    You guys keep looking in the artsy fartsy supply houses. Go to the Ag store (example link... Because shipping this stuff costs more than the graphite!)
    Graphite is used by the pounds to help lube seeds for planting. Farmers are cheap! so if the lubes expensive they will not use it. 5 lbs for $15 (us).
    If you factor in the shipping the $20 5Lbs on Amazon is a better deal if you can't find a local ag Store that carries something similar. There's a cheaper blend that is graphite and talc mix. Might not be a bad option for mold release.
    dennis and HT1 like this.
  8. Rock
    Rock Lead
    https://www.rheologicaladditive.com/organophilic-bentonite-amine-treated-bentonite/
    or
    https://www.rheologicaladditive.com/organophilic-clay-use-for-fracture-fluids-cp-150/
    Both available as 25Kg craft bags.
    I do not know which is more appropriate for casting use though.
    Details:
    Amine Treated:
    Product details
    Organically modified clay control of fluid loss to the formation , Modified Bentonite CP-169
    Rheological additive CP-169 is an organic bentonite clay.Rheology modifier has high thickenning property and colloid stability. This highly efficient Organoclay is designed for oil drilling mud.Rheology Modifier shows high efficiency of forming gel, easily disperse and stable viscosity. Organobentonite can be used well without polar activating agent.
    CP-169 is an organo clay (modified montmorillonite), designed especially for use in solvent based system including intermediate and low polarity range organic liquid..
    1, Properties
    Composition Organic derivative of a montmorillonite clay
    Appearance Fine powder, white
    Moisture content (105℃,2hr) ≤3.5%
    Loss on ignition (1000℃) 29%-32%
    Bulk density 0.53g/cm3
    Fineness (<74μm, %) ≥98%
    2, Advantages
    • Exerts gelling efficiency over a wide range of intermediate and low polarity
    • Easy dispersing
    • The gel is colourless and of high clarity
    • Produce reproducible thixotropic consistency over a wide temperature range
    • Imparts particle suspension, sag resistance without impairing flow and leveling, preventing hard settling of pigment and fillers
    • Exerts strong film reinforcing action in organic binder systems
    3, Application
    CP-169 is used in the following applications:
    • Oil drilling mud
    • Paints & coatings with solvent of low to medium polarity
    • Cosmetic
    • Lubricant Grease, ink, sealant
    4, Using
    CP-169 disperses under high shear and requires a polar activator (30%~40%) for best efficiency. Heat is not required to obtain good dispersion. Addition levels are typically in 0.2%~2.0%. Polar activator (95% Ethanol or 95% Methanol) is needed. Normally addition level of polar activator is recommended to be 30%~40% of CP-169 in weight.
    Fracture Fluids details:
    Product details
    Organophilic clay use for fracture CP-150
    Organophilic Clay (CP-150)is an easy dispersing, self activating organoclay that exhibits high performance efficiency in diesel, low aromatic mineral oil, modified vegetable oil and synthetic base fluid formulation. CP-150 unique rheological structure suspends weighting materials and other solids with less increase in viscosity and gel strength than conventional bentonite. It is highly effective in distillate and mineral oil based invert fluids.
    Properties
    Composition Organically modified bentonite clay
    Appearance Off white to tan finely divided powder,
    Specific Gravity 1.7
    Bulk density 0.40~0.60g/cm³
    Advantages
    • Effectively suspends weighting materials and other solids
    • Maintains suspension over a wide temperature range
    • Eliminates need for chemical activators
    • Is easy to disperse and rapid yielding
    • Suspends weighting materials and other solids
    Application
    Organophilic Clay CP-150 is a self-activating gallant offering rapid yield development, high gel strengths, and increased efficiency. The unique properties of CP-150 are especially valuable in low-shear mud plant operations and during completion fluid manufacture at the well site
    Base oil:
    • Diesel Oils
    • Mineral Oils
    • Synthetic Oil
    • Linear and isomerized Alpha Olefins
    • Modified vegetable oil
    Viscosifying drilling Fluids:
    • All oil based drilling fluids
    • Invert emulsion fluids
    • Workover fluids
    • Fracture fluids
  9. Melterskelter
    dennis likes this.
  10. Mach
    Mach Silver
    I'm supposed to the have the VG-Plus in hand next Monday. I've got 4 sacks of it being delivered via UShip. I was planning to pick it up last Friday but the weather didn't cooperate. Shipping from the distributor was too expensive ($400) vs UShip ($175).
    Melterskelter and Tobho Mott like this.
  11. Mach
    Mach Silver
    Ok so clay arrived today. For the record, It's called VG-Plus. Its manufactured by Schlumberger. Its available via OFMP but can only be picked up from warehouses that have it in stock. The warehouse is a Schlumberger warehouse where the sacks were picked up. Its open 7 days a week if you need to pick up. The label on the bag says its organophilic clay and trace amounts of silica. It was $58.50/50 lb sack with tax. Shipping to me almost doubled the cost but if you can pick it up from one of their warehouses, it's obviously pretty cheap.
    Denis, I'll get a couple of vacuum packed bags in the mail to you this week. Shipping larger quantities could get messy if the box splits. When I ordered petrobond, it came leaking red powder everywhere.
  12. Melterskelter
    Mach, you get the prize for actually locating and getting some organophilic clay!! Way to go. Many tried, only you have succeeded.
    With respect to shipping boxes of clay, UPS Simple Rate may be the best cost option for one cubic foot lots. Up to 50 pounds in a one cubic foot box would ship from Houston to me (and I think anywhere in the US) for 29 bucks. USPS Priority Flat rate is comparable but only allows about 1/2 cu ft for roughly that price. I like your idea of packaging in vacuum bags—-they are quite sturdy. I get Satanite shipped from a commercial supplier packed only in a black lightweight garbage bag inside a single-wall USPS flat rate box. How it ever survives I do not know. I recently shipped some powder to member triple bagged in Ziplock freezer bags and strapped with tape inside a USPS box and that seemed pretty secure.
    Bottom line: good for you.
  13. Mach
    Mach Silver
    Thanks Denis, now the fun begins. The vacuum packing will work for smaller lots. Instead I've got a box-pail-bag solution that will meet the Simple Rate criteria of less than a cubic foot. The VG-Plus weighs about 33lbs/cu ft but adding in layered packaging means it'll be about half of that in final shipping. My math says 16-17 lbs. Based on the recipe that should make 250lbs of sand. I'll take some pics tomorrow of the clay and the box setup.
  14. Inspired by your success Mach, I fired off a query to a Schlumberger company in my state, there's a bit of petroleum exploration going on at the moment. They've replied to my query via email and now want to know what I'm using it for. It remains to be seen if they'll get back to me....fingers crossed.
  15. Mach
    Mach Silver
    I worked for them for many years. I was surprised to see that they were selling to the public via OFMP. I had told Jason that they wouldn't sell to direct to the public but I'm officially full of it now. So who knows, they may sell it to you. Not sure where you are but OFMP had warehouses in different states. The label on the VG-Plus has their Calgary office listed and is branded as MI-Swaco.
  16. They have VG Supreme and Versagel HT at Adelaide in South Australia, it looks like VG Supreme will be suitable and they are going to get back to me with a price per sack. They made it clear that it's up to me to arrange freight and that I should have an account with them in future as they are not set up for cash sales. Freight is going to be a killer, shipping it halfway across the country. I'm also dealing with MI-Swaco
  17. I did get a reply back about the two products listed above: Australian $220/ US $167 for a 25Kg, 52lb sack.
  18. Al2O3
    With shipping cost yet to be incurred I take it? Ouch.
  19. Mach
    Mach Silver
    So boxed up 20 lbs of clay this evening. Went with the belt and suspenders approach. I believe this will work and not leak. The box measures 10.5 x 10.5 x 14 or or 1,543 in3 which is under the limit for UPS Simple Rate. I'll get it in the mail before the weekend.
  20. Mach
    Mach Silver
    I wouldn't think that there is a nuisance charge in there but that's 3x times the US price...that's a lot of uplift.
    They're sourcing the Bentone 38 from Elementis based on the Material Safety sheet. I called Elementis @ Corpus Christi and they forwarded me to New Jersey. They never answered their phone. You may have an Oz Elementis distributor that is more reasonable.
